Reference Levels (Non-Story Levels for Better Model Control)
Pedro Melo
It would be extremely helpful to introduce the concept of Reference Levels in Archicad — similar to Revit’s Levels — which are non-structural, non-story markers used to define key vertical positions in a model (e.g. ceiling heights, parapets, window datum lines, etc.).
These levels would not function as actual stories, and would not be exported as separate floors in IFC, but would provide a consistent and visible reference for modeling and coordination.
Proposed Implementation:
  • Add a new category of levels in the Story Settings dialog, called Reference Levels
  • Reference Levels would:
    • Appear in Section/Elevation views with custom markers
    • Be usable as snapping and alignment guides
    • Be selectable in element settings (e.g. set top of wall or beam to “Ceiling RL +2.7m”)
    • Not generate story markers or impact IFC story structure
    • Have their own layer or visibility control
Optional extras:
  • Reference Levels could be grouped (e.g., Ceiling Levels, Façade Datums)
  • Could be color-coded or styled differently from real stories
Why This Is Important:
  • Improved Coordination: Ceiling levels, bulkhead lines, parapet heights, etc., can be defined and referenced clearly, without cluttering the Story structure or requiring dummy stories.
  • Cleaner IFC Export: No need for fake stories that confuse consultants or clash with structural models.
  • More Accurate Modeling: Allows modeling elements like walls, ceilings, and beams in relation to a defined height, not just the nearest story or manual height input.
  • Industry-Standard Workflow: This aligns with how many multidisciplinary teams work — especially when integrating with Revit-based consultants.
Example Use Case:
In a commercial building:
  • Ground Floor is at 0.00
  • Ceiling RL at +3.200
  • Bulkhead RL at +2.600
These are critical modeling guides, but don't warrant actual stories. Currently, workarounds like 2D lines or fake stories are used, which are not robust or parametric.
26 Comments
Rve
@Botonis
Thank you for the info. That sounds very usefull.
I can't find any video's about it on Youtube. Could you record a small video to show how is works?
Botonis
Mentor
Just uploaded a video to show how easy it is to add additional story levels.
And those settings are integrated inside the story marker. Not an object.
You can have a favorite section marker saved for every case with additional stories or settings.
VIDEO STORY MARKER
GG_rakurs
I think Building > Story > Level is an excellent approach. But, to take it a step further, it could also be Folder > Subfolder (1) > ... > Subfolder (n) and it would be more consistent with some other parts of the interface. On a not-this-wish note, it would be great to have everything in Project Map "subfolderable" and not just basic level. It would make so much more sense, and it would be much easier to organize everything. For people that don't need it - don't use it! But I believe most people would actually use it, especially when localization firms that produce templates for their users start to implement it. THAT would bring consistency to more parts of the UX / UI.
Gerard Santos
Hi everyone,
As an architect with years of experience in developing executive projects and BIM coordination, I want to add my full support to this wish. Without a doubt, the addition of Reference Levels independent of Stories would be a massive leap forward for Archicad.
In the real world of construction and design, a building is much more than just its main floor slabs. We constantly need parametric references for elements that dictate the project's geometry, but which absolutely do not justify creating a new Story. Some everyday examples include:
• Suspended ceilings and soffits: Elevations that can vary across different zones within the same floor.
• Structural elements: Top of beams, stepped foundation levels, or anchor plates.
• Architectural details: Stair landings, roof parapets, or window/door lintels.
Why is this so necessary?
Currently, the workaround of creating "dummy" Stories to anchor these elements ends up cluttering the Project Map, complicating section views, causing errors in schedules, and interfering with proper IFC classification (where a parapet should never be read as a building story).
Having parametric Reference Levels that are not linked to Stories would allow us to:
1. Keep the model tidy: A Story structure that stays true to the actual architectural layout.
2. Gain better parametric control: If a suspended ceiling's elevation changes, all elements linked to it would adjust automatically, greatly reducing human error.
3. Improve collaboration: A cleaner model is infinitely easier for engineers and other consultants to understand.
I sincerely hope the Graphisoft development team prioritizes this feature. It would give us architects a much more natural, logical, and construction-oriented control over our models. You have my full vote!
Ahmed_K
Mentor
this wish is a must have, + 1000 for that.
i wish we get it as soon as possible !
bdonovanAS
I want this so bad!  If we are going to be paying through the nose for this product, then add more of these features that we all want!!!
Status
Submitted
with 164 Votes
Wish details
Labels
