Refresh Licence
Lingwisyer2
Hi all,
This wish is for the ability to "refresh licence" or "re-check available licences" when AC detects that there is no valid licence.
Scenario 1: There is no available licence because someone forgot to upload theirs when they were finished with it, or you have a mix of licences which are not all current. We all know ACs startup has slowed down significantly over the past few iterations, and this just means you have to go through it all over again after ensuring a licence is available as the only option given is to quit AC. Having an option to "re-check available licences" would save this pain...
Scenario 2: You need to change GS Account, for what ever reason. You now need to restart every AC instance you have open, even though you have already signed in and reserved a valid licence... On top of that, it throws you back through the initial AC startup...
Ling.
ps. When you force release a cloud AC licence, the user is not immediately kicked. I assume this has to do with the whole licence validation shananigans that were preventing cloud users from doing any work when cloud licences first came out, that it now only periodically checks and hopefully tries a few times. I did not wait to see what happens when the user finally gets kicked off, and what would happen if a licence was available again.
pss. This might all be different if you only have access to cloud licences?
1 Comment
Eduardo Rolon
In addition it would be better if they copied Rhino's s were the software is in charge of releasing the license and you don't have to keep going to the website to release and refresh.
Status
Submitted
with 2 Votes
Wish details
