Relative file locations for embedded files and publishing sets
Pato99
Hi this was an old request in the now archived wishlist forum from 1904, pretty sure it had at least 10000 up-votes. In any case.
Please add relative links for the following:
1. Project Info
    Because automation is a thing now, I automate the creation of the .xml in every job folder and it needs to be painfully, manually imported for every job. When you open the project or update the drawing manager it should check for an update to the .xml file
2. Publishing Location
    More painful than having a baby I hear, is setting the publishing location in ArchiCAD each time a different user takes over a job.
3. Embedded Images, PDF's & DWG's
    a. QR Codes, magical, auto-generated goodness! Automatically dropped in the project folder should allow relative links into the title block, which would direct end users to a website to confirm plans are the latest set
    b. Details, Details, Details
1 Comment
Burak
I think those will be implemented in Archicad 39 🤔
Status
Open
with 30/200 Votes 6.666666666667%
Wish details
