Renovation filter on curtain wall elements
peder ravn
Working with existing buildings where you want to remove an element inside a curtain wall (for example a door), the only solution now is to have two different files for new and existing situation. It would be practical to use the renovation filter to keep everything in one file.
2 Comments
ralfa omeo
Hi!
Have you tried restarting your computer?
Not to take away from the validity of the wish:
In the meanwhile, you could try using Design Options so that you could have the two phases of the Curtain Wall in the same file. It is a workaround, but may be better than working with multiple files.
Status
Submitted
with 5 Votes
Wish details
