Changing the materiality along the length of a wall (e.g. color / cladding change) typically involves breaking the walls as needed. This frequently occurs in alignment with fenestration such as doors and windows.
Unfortunately it is entirely dependent on 100% accuracy - if the wall is cut the tiniest fraction off, the door or window ends up outside the wall and becomes invisible in plan. Often teams then place said door or window again to get it to display - which effectively duplicates these instances, throwing out the quantity in schedules.
Having a feature such as "highlight doors and windows placed outside wall" would really help with cleaning these instances up!
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
