Single Component Structure Skin Type
LucaP
I would love to finally be able to create elements with Basic structure and have the possibility to set its skin type (i.e. Core, Finish or Other) for that element. That especially applies to slabs where the workarounds are very limited, but I would be happy to see it applied to Walls, Columns, Beams, Roofs and Shells as well.
At the moment I have to resort to creating couple of Composite structures for a slab, whenever I need to create for example additional insulation layer. I can't even use Complex profiles - the only option is to create couple of thicknesses of such structures (10cm, 12cm, 15cm and so on...) whenever I need them to be other than Core type.
I believe I'm not the only one, since there are also few scenarios where that functionality would be helpful (intersections of Slab's Core layer in door openings).
Status
Submitted
with 2 Votes
Wish details
