After moving the origin or direction of a 2D Cover Fill on a slab or roof, the origin/direction of the corresponding Surface texture image in 3D should also update.
For example, modeling an acoustic ceiling grid or floor tile pattern, setting the 2D Cover Fill origin and direction in plan should also set the origin and direction of the 3D texture, so that the model view and plan view match.
Currently, one has to manually align the 3D textures in the 3D window, which is an extra, and time consuming, step.
