Here's the problem: I have a drawing on a layout. The view is of a text box with an offset border. In the view, the nodes are on the border and things can snap to the edge or corner, but when placed on a layout, suddenly I can't snap to the offset border, only to the outside of the text (as if no offset - see attached [the blue circle is where the pointer is]), so the border would get cropped out.
Do I need to explain the solution? Allow us to snap to an offset border when views are placed on a layout.
Try it out. It's frustrating. It's frustrating minutiae, but it should be fixed.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 0 Votes
