The Problem:
Pretty much on every project...ever, we need to show the tread number for the treads of the steps in section. There is an existing, time consuming method for numbering the treads. It is more of a work-around rather than a reasonable solution see (https://community.graphisoft.com/t5/Documentation/Stair-flight-numbers-in-section/ta-p/303825).
The Solution requested:
What should be available is a checkbox to show it or not in section in the stair object. The information is already built into the stair object. I get that this isn't super simple since the stair object is a complex 3d object. However, if it can be managed manually it should be possible to automate it.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
