Would it not be great if you could open Teamwork projects via a desktop shortcut?
Imagine being able to open a TW file from within your company filing system much like you would a PLN. If you are signed in and have already joined the project, it would just open as if you were opening any other pln file. If you had not joined, it would ask if you would like to join given you have permissions to do so. If you are not signed in, or do not have permissions, it would ask you to sign in with an account that has the requisite permissions. This would be especially useful if you work with both pln and tw models as it would remove the need to remember which model is which, and if you migrate a project from pln to tw, opening it from a file manager would be seamless.
Ling.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
