Teamwork: Open via Desktop Shortcut
Guru
https://community.graphisoft.com/t5/Installation-update/Open-teamwork-project-via-desktop-shortcut/m...
Would it not be great if you could open Teamwork projects via a desktop shortcut?
Imagine being able to open a TW file from within your company filing system much like you would a PLN. If you are signed in and have already joined the project, it would just open as if you were opening any other pln file. If you had not joined, it would ask if you would like to join given you have permissions to do so. If you are not signed in, or do not have permissions, it would ask you to sign in with an account that has the requisite permissions. This would be especially useful if you work with both pln and tw models as it would remove the need to remember which model is which, and if you migrate a project from pln to tw, opening it from a file manager would be seamless.
Ling.
4 Comments
torben_wadlinger
You mean something like an Explorer-Window or a Finder-Window from where you can start every project that is hostet on your server(s) with a single double click? With the right Archicad version?
Well, I made myself an universal BIMCLOUD-Launcher for macos and windows. Just send me a pm and I'll send it to you, if you like.
But I will first have to translate it.
Guru
Nope. A shortcut that you can open a TW project from that sits within the same filing system as your non-TW projects, consultant receivables and post-production files.
Your launcher does look great though if all of your projects are TW and across multiple versions.
torben_wadlinger
A simple shortcut will not work, because you need to authenticate against the bimcloud-server. My tool does exactly what you ask for: it creates a command that starts Archicad with a command line parameter which includes the authentication of the registered user. But the credentials are sent in plain text. This is all handled inside the software for that there is only minimal security risk. Maybe it’s possible but not as a link or an alias but as a script which pulls the credentials from the local preferences or registry …
let me think about it …
Guru
There should be no need to authenticate before AC is launched, as that would be done during startup, and if it cannot validate, it should just throw up the login dialogue. This would be identical to the proccess of opening a project from the recent files list.
Ling.
Status
Open
with 5/200 Votes 40%
Wish details
