A useful hand-drawn and 2D CAD technique is to have a thick line around edges of elements which are in front of another. In ArchiCAD I would like this feature to help give depth to elevations, without having to manually trace. For instance, a wall can have an uncut line type but there is no difference to a line indicating a wall opening or change in material, to a line which is the edge of a wall. I imagine this would be a check box in elevation settings along with shadows, transparency, etc, and a line type chosen as the 'thick' line. There may also need to be a threshold depending on how such a feature is processed.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 0/200 Votes
