UI - Windows Open-Save etc dialog boxes -please change the old outdated and hardly usable ones
Originally I posted this on Insiders panel, but I was suggested to also make it here:
UI - Windows Open-Save etc dialog boxes -please change the old outdated and hardly usable ones to the new ones which are the standard now and they are for a long time in the standard frameworks.
Example: Open & Save:
Please change to:
Much more usable with straight forward path usage (copy paste and so on, yes I know already possible)
The most horrible dialog is when exporting a library:
Please use: System.Windows.Forms.FolderBrowserDialog instead this unusable current dialog.
2 Comments
rakurs
This hits the spot.
It's also frustrating how save as... goes to the folder where last save as... command was used, and not in the folder from which the file you have opened is originating from. This results in saving projects in other projects' folders if I'm not careful enough.
SimSmi1
Absolutely!! I need the ability to pin favourite locations but instead have go looking for my project folders. Using the windows standard dialog would also allow copying and pasting of file paths into the address bar. It would also allow use of third party search apps such as TechHit Quickjump
Status
Submitted
with 14 Votes
Wish details
