Similar to the new uniform insulation button add a uniform route specification as mock up below.
Currently, you need to change the branch, segment, elbow and transition on three separate tabs and fields.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 2 Votes
