Unify Walls, Slabs, Roofs, etc.
Patrick M
It would save a lot of time and make AC more intuitive if there were additional edit functions to consolidate walls, slabs, roofs, etc. If I have a chain of walls or abutting slabs, the only way to unify is to adjust one element and delete the other(s).
2 Comments
danielk
Yep, unifying/consolidating 3D elements is something that is sorely missed.
What I usually do for slabs btw is select slab 1, use magic wand to add the outline of the slab 2, and then delete slab 2. But it is a lot of extra steps, if there are more than one slabs, you need to keep repeating, and holes/openings also need to be re-added.
Patrick M
Danielk, yeah, the magic wand works... but if you have any solid element operations or other trimming body associations, they need to be redone when you delete the redundant slab portions
Status
Submitted
with 7 Votes
Wish details
Product
Labels
