Users have the ability to create the different settings on the bottom of the screen, such as Layer Combinations, GO Combinations, Renovation Filter Options, etc.. I think it would be helpful to add another settings tab that stores/saves the combination of these already combinations into a Quick View Options or View Map Options. This would be very similar to what is already saved with a particular view under the view map. However, having the ability to see this combination independently from the view map seems like a logical step.
Personally I often times have a saved view set with a particular view. Let's say it is a floor plan view. When I go to a section, it might have a completely different set of combinations, which dont correspond to what I was just working on in the floor plan. Having the ability to quickly toggle one setting, the section can now use the saved View Map Option but in the different view.
In my opinion it's almost there already. It would be a time saver for me personally.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 0 Votes
