WISH: Performance metrics
Archireid
2 aspects to this wish:
A way to determine which system will perform better in archicad, either a built in benchmark, or some way of seeing view load times, rebuild times, frame rate in 3d views etc
Currently the only reference for performance that I know of is the minimum and recommended specs which rarely get updated.
Secondly these performance metrics could be used to help diagnose performance issues - ie: is a particular view taking longer that the others, or a specific object slowing everything down, or running out of ram etc
I'm fairly sure some of this info is already available in the session report window, but having it all in a concise, accessible format with repeatable results to compare systems or projects would help.
11 Comments
Davor P
Perhaps not entirely what @Laurentiu has outlined here, but the Audit Tool addon I have developed captures quite a bit of info about a project. You can then use this info to asses potential issues in files. Using the addon in the office where I work as a BIM manager has already proven very helpful.
Status
Upvoted
with 48 Votes
Wish details
