Often I need to create some kind of wall which will be trimmed on the top part in diagonal. For example a wall along stairs ...
To do so there is several approach :
- Create a roof and trim with roof and hide roof or
- Create a roof and crop
- Create a morph from wall but it lost some editing possibility (and morph editing is messy)
- Create a special profil in 2D
- Solid element operation and then hide operator element
They are all taking time and need to create other component to arrived to such result.
After all there are already several way to create wall with different thickness for example but this is only for the 2D plan.
I which there would be a fast way to do the same "verticaly", editing wall height at both end of the wall :
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
