WISH: to have subkeynotes that you can add to the description of main keynotes
Before AC28 we used the project info to create labels for floorplans/sections/details, where 1 item of the project info would have multiple lines of text.
ex:
Wall exterior
-concrete wall
-insulation kingspan xx
-stucco
The problem is that you end up with multiple material descriptions that repeat themselves, and when you need to change them, you need to find and edit that text in multiple project info tabs.
Keynotes are way better than project info, but it would be nice if you could make sub-keynotes that one could add to a main keynote description.
Thanks
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 0 Votes
