Design options search options
Joostm
WISH: to be able to quickly see and search design options in placed modules
We use design options as modules to save multiple options in 1 floor instead of using the iceberg method.
The find & select tool doesn't work options inside placed modules
To find which design option is turned on, I have to open the hotlink settings and that's not efficient.
It would be amazing to :
  • search with the Find & select
  • see which option is on when you hover over an element
Thanks!!
1 Comment
Lachlan Green
It would be good if the original design option was shown when hovering over an element.  We are starting to use design options in combination with the iceberg method more.  Coming on to a project and finding your way back to the source element can be tricky, especially if design options aren't named clearly.
I'd suggest the element's original design option should be included in the top line e.g. "Part of HLM (-11. Gevels.mod - - 11/Gevels : Design Option ###)".  Nested modules wouldn't be an issue as the referenced HLM is always the initial module.  Currently, if the module itself is linked to a design option, that option appears where you've suggested.
Status
Open
with 7/200 Votes 28.571428571429%
Wish details
Product
Labels
