"Enter" selects from library instead of closing window
NateLumen
The Problem: (see screen recording attached which includes two "Enters") You open up a tool and search for something. You close the tool. Then you select something that tool makes (like the object tool makes objects). You use your keyboard to tab through some settings, maybe from a drop down, then hit enter to select. That setting is selected. You hit enter again to select "OK" and close the window BUT instead of OK and closing the window, you've suddenly switched from the object you were editing to whatever you were searching the library for before. You proceed to pull your hair out.
The Solution: Even when the search is active (with a cursor), a second Enter closes the window instead of selecting a library part in the sidebar. You leave your hair in.
Has anyone else encountered this problem?
1 Comment
2D
holy crap
Status
Submitted
with 2 Votes
Wish details
