Sefa Yakut
Ai Assistant in Archicad - Gemini Flash 1.5 Visual Creation
I noticed that visual creation capabilities have been added to Ai Assistant. If I remember correctly, this wasn't available until recently. HOWEVER, when I asked it what model it was using, it said it was using the Gemini 1.5 Flash Ai model. Although this model is a cheap model but it is a very simple model in terms of visual creation and providing consistent results. Will there be any updates related to this?
Mohamed Raslan
Thank you Sefa for the observation and feedback. We are updated the model to Gemini 2.5 flash as the model used for answers but it seems that it wasn't updated on the user guide which the LLM is using as a reference to answer questions about itself.
Also, we are using the AI viusalizer diffusion model to generate the images within the AI Assistant. And we know the generated images quality problem, and we are actively working on an upcoming upgrade for the image generation model.
Mohamed Raslan
Product Designer, Graphisoft
[email protected]
