go
Sefa Yakut
since ‎2023-07-26
58 seconds ago
User Statistics
  • 96 Posts
  • 8 Solutions
  • 30 Likes given
  • 62 Likes received
User activity
Hi, Although Archicad’s automatic dimensioning is very useful, it didn’t generate dimensions that conformed to the dimensioning conventions in my country (Turkiye). I had to make adjustments manually for items such as dimensioning the spacing between axes or providing genera...
Hi all, I wanted to explore a different use for Design Options in Archicad: presenting movement through a sequence of model states. With support from ChatGPT-6 Astra, I developed a workflow covering model preparation, Design Option setup and image exports. For this experimen...
Hi, I am experiencing an issue during IFC export regarding the automatically generated 'IfcOpeningElement' entities created by doors and windows. When validating our IFC models against strict IDS (Information Delivery Specification) requirements, these automatically generate...
Hi, Although our user has assigned licenses to company members, when they try to connect to a project via BIMCloud SaaS, they receive the message “You don’t have a BIMCloud license yet.” When I check via the BIMCloud SaaS web interface, I see a “insufficient licenses” warnin...
Hi, When converting from Archicad to AutoCAD, if you add text to level dimensions manually, that text appears as two lines in AutoCAD for some unknown reason. Manually adjusting this text in AutoCAD to make it a single line is quite difficult. Here’s the solution I came up w...
