Got a minute? We appreciate your feedback:
Graphisoft Learn survey
Archicad AI Visualizer
AI doesn't work
Martin_S
The AI for Archicad 27 isn't functioning on my MacBook Pro M1. I'm encountering the following error message: RuntimeError: MPS backend out of memory (MPS allocated: 16.84 GB, other allocations: 1.30 GB, max allowed: 18.13 GB). Tried to allocate 10.00 MB on private pool. Use PYTORCH_MPS_HIGH_WATERMARK_RATIO=0.0 to disable upper limit for memory allocations (may cause system failure).
6 REPLIES 6
lopezfigueroa
same error in windows 10
Alfredo1
Same error, I tried on Windows and Mac
edseiber
Installed last Friday on my MacBook Pro M1 Max 64 GB Memory. Seemed to work fine initially, but now I get the attached error message. Any advice?
Not aware that I changed any base parameters, but could have by accident.
Illes Papp
Can you please provide a screenshot of your command prompt?
Illés Papp
GRAPHISOFT Senior Product Manager
Do you remember making any manual changes on your JSON file, mentioned in the error message?
Illés Papp
Is this what you're looking for?
