2023-11-17
11:00 PM
2023-11-18
01:59 AM
The AI for Archicad 27 isn't functioning on my MacBook Pro M1. I'm encountering the following error message: RuntimeError: MPS backend out of memory (MPS allocated: 16.84 GB, other allocations: 1.30 GB, max allowed: 18.13 GB). Tried to allocate 10.00 MB on private pool. Use PYTORCH_MPS_HIGH_WATERMARK_RATIO=0.0 to disable upper limit for memory allocations (may cause system failure).
2023-11-18 10:22 PM
same error in windows 10
2023-11-18 11:46 PM
Same error, I tried on Windows and Mac
2023-11-21
05:02 PM
2023-11-22
02:33 AM
Installed last Friday on my MacBook Pro M1 Max 64 GB Memory. Seemed to work fine initially, but now I get the attached error message. Any advice?
Not aware that I changed any base parameters, but could have by accident.
2023-11-24 02:39 PM
Can you please provide a screenshot of your command prompt?
2023-11-24 02:40 PM
Do you remember making any manual changes on your JSON file, mentioned in the error message?
2023-11-24
03:14 PM
2023-11-26
07:00 PM
Is this what you're looking for?
2023-12-21 12:41 AM
I have been getting the same issue:
My GPU: memory:
From my reading, my laptop selects which GPU to use based on a performance level (Windows 11: System>Display>Graphics). I have tried changing the performance setting from 'Let Windows Decide' to high performance for ArchiCAD 27 and Python (from C:\sd.webui\system\python) but still get the same prompt./
2023-12-28 11:57 AM
Hi edseiber,
I remember you had this issue previously and wrote this:
"My issue is now resolved. I discovered I had the JSON Config Template nested within the AI Visualizer folder under the Extras folder. Once I removed the JSON Config Template from the AI Visualizer folder and placed it directly in Extras, images generated fine"
Can you please check this again?
Have a Happy New Year!
Kind regards,
Technical Support Engineer
2023-12-28 11:59 AM
Hi wilson0083,
Please note that the minimum system requirement to use the Add-on is: 8 GB of VRAM on Windows and 16 GB of RAM on Apple Silicon.
For the detailed requirements read the system requirements.
Kind regards,
