2023-11-17
11:00 PM
2023-11-18
01:59 AM
The AI for Archicad 27 isn't functioning on my MacBook Pro M1. I'm encountering the following error message: RuntimeError: MPS backend out of memory (MPS allocated: 16.84 GB, other allocations: 1.30 GB, max allowed: 18.13 GB). Tried to allocate 10.00 MB on private pool. Use PYTORCH_MPS_HIGH_WATERMARK_RATIO=0.0 to disable upper limit for memory allocations (may cause system failure).
2023-12-28 01:31 PM
2023-12-28 03:28 PM
Hi, Norbert.
Yes, the simple fix I described previously continues to work. I've been generating images with no problem.
Happy New Year to you as well.
2023-12-29 10:20 AM
Hi wilson0083,
Thanks for your answer.
Shared GPU usage is not doable at the moment. The Add-on requires 8 GB if dedicated VRAM, you have 6 GB.
The "PYTORCH_CUDA_ALLOC_CONF " does not help this case unfortunately.
Sorry for the inconvenience.
Kind regards,
Technical Support Engineer
