Read more
Archicad AI Visualizer
Discussions about Archicad AI Visualizer.
Does AI Visualizer understand dimensions?
PV1972
Hi!
I haven't tested AI Visualizer yet. I'm curious to know if it understands the dimensions of the model. The basic model in ArchiCAD is made in real life dimensions, of course. So let's say I have a a "box" 6...7 meters in height. Does AI Visualizer understand that and make (quite propably) 2-story building? Or can it be anything?
First I thought it would understand it, but now while writing this I came to opposite thought. 🙂
Thanks!
4 REPLIES 4
Yes.  Simply look at the examples posted by people and you can see that the model size is understood.
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.7, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Oh yes, the Gallery. Didn't notice that. Thanks!
David Collins
The AI Visualizer team talked about this in their webinar.
The visualizer only sees and understands a flat image, so it never gets any dimensional information from ArchiCAD’s 3d model. Instead, it tries to interpret clues both from the image and the prompt. An “office building” will get more stories than a “house.”  I’ve found that placing a person somewhere in the image can help the Visualizer better understand the scale.
David Collins
Win10 64bit Intel i7 6700 3.40 Ghz, 32 Gb RAM, GeForce RTX 3070
AC 27.0 (4001 INT FULL)
Thanks for clarifying, @David Collins   I totally misunderstood what info the visualizer worked from... as I didn't attend the webinar (and have no interest given all of the machine installation hacks required to test this preview technology).  Given all of the open AI image models that just work with flat images, I just assumed that Graphisoft was doing something special/advanced that took the actual model into account.  Oh well.
