We value your input!
Archicad AI Visualizer
Discussions about Archicad AI Visualizer.
This group is dedicated to the experimental AI Visualizer for Archicad 27, which will reach End of Service on December 31, 2024.
The new AI Visualizer in Archicad 28 is now fully cloud-based, with advanced controls like creativity and upscaling. Click here for further details.
Installation Issues
TKnudsen
I'm having problems installing step 4 in the terminal.
It says that there is no such file or directory.
Anyone has a clue to what might be causing this?
1 REPLY 1
Norbert Kucsma
Hi TKnudsen,
I suspect that you are trying to install the Add-on on an Intel Mac. Please note, that the AI Engine of the Add-on does not run on Intel Macs.
You can install Stable Diffusion server ('sd.webui' folder) on an Apple Silicon device and specify the address of this server in the AI Visualiser UI on your Intel Mac. The Intel device will send requests to the Apple Silicon one (set as the server) and you'll get the result in Archicad. In order to make this work the mentioned folder should be added to the Archicad27/Add-Ons/Extras folder on the Intel Mac.
In case you are trying to install it on an Apple Silicon Mac please contact your local support.
Kind regards,
Norbert Kucsma
Technical Support Engineer
