This group is dedicated to the experimental AI Visualizer for Archicad 27, which will reach End of Service on December 31, 2024.
The new AI Visualizer in Archicad 28 is now fully cloud-based, with advanced controls like creativity and upscaling. Click here for further details.
2024-07-19 01:18 PM - last edited on 2024-07-23 02:39 PM by Laszlo Nagy
After installing, throw the "AI_Visualizer-Installation_Guide"
i have an issue after running "run.sh"
The Command stops with the Prompt:
Please use pip<24.1 if you need to use this version.
ERROR: Could not find a version that satisfies the requirement torchsde==0.2.5 (from versions: 0.2.5, 0.2.6)
ERROR: No matching distribution found for torchsde==0.2.5
Has someone a workaround for this?
2024-09-11 10:21 AM
Hey guys,
would love to find a solution to this problem to finally be able to start rendering some images!
Where are you looking forward to solution please let me know!
Kind regrets
2024-09-11 11:45 AM
Hi Norbert. Any update about this issues?
2024-09-11 12:07 PM
Hi all,
We apologize for the delay and plan to release a new installer package next week.
Kind regards,
Technical Support Engineer
2024-09-11 12:12 PM
Thank you for your quick response!! can't wait to see the update. please inform if the new package is ready. thank you
2024-09-16 01:18 PM
Please inform when it is released 🙂
2024-09-18 09:14 PM
How is the Update going?
2024-09-23 03:41 AM
Hi Nobert, hope you are well. Any update for this issue??
2024-09-23 12:26 PM - last edited on 2024-09-23 07:34 PM by Laszlo Nagy
Sorry for the delay and thank you for your patience.
The new installer for macOS and the updated installation guide are available on this site.
Kind regards,
2024-09-23 08:20 PM
HI Norbert,
Im still facing challenge here..
I have downloaded the new Visualiser Package and followed the steps all the way to Step no 4. (for Mac Silicon) and then I get this comment from the Terminal:
Step 1. --- Update to v1.10.1...
/Volumes/AI_Visualizer_Add-on-27-INT-install_package-MAC/sd.webui/install.sh: line 23: cd: webui: No such file or directory
xxx@ewas-mbp ~ %
Im not able to install further...
Does anyone have the the same issue ?
2024-09-23 08:46 PM
i´m having this issue :
File "/Applications/Graphisoft/Archicad 27/sd.webui/webui/venv/lib/python3.10/site-packages/requests/adapters.py", line 700, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='localhost', port=7860): Max retries exceeded with url: /startup-events (Caused by NameResolutionError("<urllib3.connection.HTTPConnection object at 0x2db1f8160>: Failed to resolve 'localhost' ([Errno 8] nodename nor servname provided, or not known)"))
Creating model from config: /Applications/Graphisoft/Archicad 27/sd.webui/webui/repositories/generative-models/configs/inference/sd_xl_base.yaml
Applying attention optimization: sub-quadratic... done.
Model loaded in 26.3s (load weights from disk: 0.6s, create model: 0.6s, apply weights to model: 22.7s, apply half(): 0.2s, apply dtype to VAE: 0.1s, move model to device: 0.2s, calculate empty prompt: 1.7s).
