Koze85
AC API automatic update of a textbox
Hi can I automatically update a textbox with the Area of a specific fill whenever a user change its shape?
1 Solution
Hi!
You can attach observers to elements. In the handler proc you can then put the code to update the textbox. Check out the section "Element related notifications" on this page: Notification Manager | Archicad API.
Also check out the Notification_Manager example coming with the API DevKit.
Automating Archicad with Add-Ons, GDL-Objects & Python Archi-XT.com
Go to post
3 Replies 3
julienK
Texdtbox don't have an asociative property so I'm not sure it can be done.
You should use an associative label for this.
Hi!
Koze85
Thanks it was of the few examples I hadnt compile and tried!
