Learn more
AC17 Rendering API
The sample project does not compile (cannot find Vector3D.hpp). Including C:\Program Files %28x86%29\GRAPHISOFT\API Development Kit 17\Support\Modules\Geometry in the incl directories fixes that. But then it's missing MakePreviewData in the linking stage, which I cannot resolve.
Has anyone successfully compiled the AC17 rendering API sample yet?
4 Replies 4
PBartke
Graphisoft Alumni
Graphisoft Alumni
I think there is a mistake in RendererImp.hpp.
Open it (it should be somewhere in \Inc\RenderingDevLib\RendererImp.hpp) and change the declaration of MakePreviewData so it is an empty method (just like CancelAsync the method before MakePreviewData ). That should do the trick.
Thank you. That resolves the issue.
Marton Kiss
Thanks guys for bringing this up. We are going to check this on our end.
Marton Kiss
Chief Product Officer
GRAPHISOFT
Marton Kiss
We've check it here, for AC 17 please use the workaround PBartke has mentioned and for the next DEV-Kit we will have this fixed.
Marton
Marton Kiss
GRAPHISOFT
