sijocherian
Issue with Column Rotation in Code
Hi team
I am reaching out regarding an issue I encountered while attempting to rotate a column by its own axis using code.
I have utilized the following code snippet:
	element.column.head.floorInd = short(storey);
	element.column.origoPos = beg;
	element.column.coreAnchor = 6;
	element.column.relativeTopStory = 0;
	element.column.height = height;
	element.column.bottomOffset = baseOffset;
	element.column.isSlanted = true;
	memo.columnSegments[0].assemblySegmentData.isWidthAndHeightLinked = false;
	memo.columnSegments[0].assemblySegmentData.nominalWidth = width;
	memo.columnSegments[0].assemblySegmentData.nominalHeight = breadth;
	element.column.axisRotationAngle = 0.785398;
	err = ACAPI_Element_Create(&element, &memo);
Despite setting the axisRotationAngle to 0.785398 (which corresponds to 45 degrees), I am not observing any rotation of the column upon rendering.
However, I can achieve the desired rotation angle through the user interface.
Could you please advise if there is anything I might be missing or if there is an alternative approach to achieve the desired rotation angle programmatically?
Thank you very much for your assistance
1 Solution
Hiromichi Shinkawa
The axisRotationAngle should works in latest version (AC27.2.0). If you still meet the problem please try the following code (I just added two lines as first):
    element.header.type = API_ColumnID;
    GSErrCode err = ACAPI_Element_GetDefaults (&element, &memo);
Go to post
Hiromichi Shinkawa
