2024-03-20
08:29 AM
2024-09-16
02:59 PM
Doreena Deng
Hi team
I am reaching out regarding an issue I encountered while attempting to rotate a column by its own axis using code.
I have utilized the following code snippet:
element.column.head.floorInd = short(storey);
element.column.origoPos = beg;
element.column.coreAnchor = 6;
element.column.relativeTopStory = 0;
element.column.height = height;
element.column.bottomOffset = baseOffset;
element.column.isSlanted = true;
memo.columnSegments[0].assemblySegmentData.isWidthAndHeightLinked = false;
memo.columnSegments[0].assemblySegmentData.nominalWidth = width;
memo.columnSegments[0].assemblySegmentData.nominalHeight = breadth;
element.column.axisRotationAngle = 0.785398;
err = ACAPI_Element_Create(&element, &memo);
Despite setting the axisRotationAngle to 0.785398 (which corresponds to 45 degrees), I am not observing any rotation of the column upon rendering.
However, I can achieve the desired rotation angle through the user interface.
Could you please advise if there is anything I might be missing or if there is an alternative approach to achieve the desired rotation angle programmatically?
Thank you very much for your assistance
Solved! Go to Solution.
2024-05-09
11:06 AM
2024-05-11
05:22 AM
The axisRotationAngle should works in latest version (AC27.2.0). If you still meet the problem please try the following code (I just added two lines as first):
element.header.type = API_ColumnID;
GSErrCode err = ACAPI_Element_GetDefaults (&element, &memo);
2024-05-09
11:06 AM
2024-05-11
05:22 AM
