Friday
In Archicad25
The rotation of an object (column/beam) on the XY plane can be obtained using "angle", but how do you obtain "slantAnge" and "slantDirectionAngle"?
Also, the starting point is "pos", but how do you obtain the coordinates that correspond to "endPos" in the case of a beam?
Friday - last edited Friday
Hi.
You can get the element properties through the element type structures as shown below.
element.column.slantAngle
element.column.slantDirectionAngle
The help files installed in the following locations will help you.
C:\Program Files\GRAPHISOFT\API Development Kit 24.3009\Documentation\MSDN\APIDevKit
The start and end points of beams can be obtained using begC and begE properties.
element.beam.begC
element.beam.begE
