‎2011-10-31
10:42 AM
‎2023-08-02
09:06 PM
Doreena Deng
‎2011-11-08 06:06 PM
BimThomas wrote:This turned out to be a bug in AC15. The IFC add-on was rewritten, and this feature fell through the gap. Unfortunately there's no workaround at the moment, as the "Save as IFC" functionality is not registered as a module command.
Hi all,
I have compiled the Automate_Functions example of the AC15 DevKit. While most of the example functionality indeed does work, the "Save as Ifc" menu item triggers the following error message "Error in APIDo_SaveID (Ifc): ???" a little further investigation shows that the error code that is returned is -7003 or simply GSErrCodes::Error. I badly need to programmatically export IFC files from Archicad, therefore any help would be tremendously appreciated. Does anyone else experience this problem? I am using the win64 version of AC15. Thanks in advance.
Kind regards,
Thomas
‎2011-11-08 06:30 PM
‎2011-11-21 04:48 PM
BimThomas wrote:FYI this issue will be fixed in the next AC15 hot fix.
Wow that's unfortunate. Well, thanks for investigating the issue.
Kind regards,
Thomas
