Archicad C++ API
API_ApplicationPrefsFolderID
Hello All !
I seek the folder which corresponds to API_ApplicationPrefsFolderID on windows ?
Indded, i think i'ts a hidden folder. If anyone knows the path to acces.
Thank in advance
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
yes, it's a hidden folder, it points to the following:
\Users\<YourWindowsUserName>\AppData\Roaming\Graphisoft\ArchiCAD<Version>\
Best Regards,
Tibor
thank you very much, sir Tibor !
