Archicad C++ API
Librairie compil Visual Studio 2010
Hello All !!
When i build my project, i have an error this is :
ACAP_STAT.lib(ACAPlib.obj) : warning LNK4099: PDB 'api_c.pdb' cannot found with 'ACAP_STAT.lib(ACAPlib.obj)' or C:\....\Examples\Myproject\api_c.pdb ; object will be linked whitout debug information
Indeed, my project build but this error disturb me...
If somebody can help me... Thank You !
Sincerly
2 REPLIES 2
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
It's not your fault. We'll try to fix this for the next DevKit version.
This is just a warning which means that the debug information for that file wasn't found. Even so, you will still be able to debug your own code.
Best Regards,
Tibor
Ok, thank you !
I can sleep peacefully !
