2018-12-06
03:21 AM
2022-10-04
04:51 PM
Daniel Kassai
Severity Code Description Project File Line Suppression Statecode for Database_Control.cpp file
Warning C4189 'aaaa': local variable is initialized but not referenced Database_Control C:\Program Files\Graphisoft\API Development Kit 22.3004\Examples\Database_Control\Src\Database_Control.cpp 1458
Error (active) E0028 expression must have a constant value Database_Control C:\Program Files\Graphisoft\API Development Kit 22.3004\Support\Modules\GSRoot\GSException.hpp 62
Error (active) E0145 member "GS::GSException::AlignOfUniString" may not be initialized Database_Control C:\Program Files\Graphisoft\API Development Kit 22.3004\Support\Modules\GSRoot\GSException.hpp 56
Error (active) E0145 member "GS::GSException::SizeOfUniString" may not be initialized Database_Control C:\Program Files\Graphisoft\API Development Kit 22.3004\Support\Modules\GSRoot\GSException.hpp 57
Error C2220 warning treated as error - no 'object' file generated Database_Control C:\Program Files\Graphisoft\API Development Kit 22.3004\Examples\Database_Control\Src\Database_Control.cpp 1458
static void Do_ExportWallsToExcel (void)
DBPrintf ("Exporting walls to Excel document...\n");
libxl::Book* book = xlCreateXMLBook ();
libxl::Sheet* sheet = book->addSheet (UNISTR_TO_LIBXLSTR (GS::UniString("Walls exported from Archicad")));
libxl::Font* guidFormatFont = book->addFont ();
guidFormatFont->setSize (6);
guidFormatFont->setColor (libxl::COLOR_GRAY50);
libxl::Format* guidFormat = book->addFormat ();
guidFormat->setFont (guidFormatFont);
GS::Array<GS::UniString> titles;
titles.Push ("GUID");
titles.Push ("Height");
titles.Push ("BeginCoordX");
titles.Push ("BeginCoordY");
titles.Push ("EndCoordX");
titles.Push ("EndCoordY");
for (UIndex i = 0; i < titles.GetSize (); ++i) {
sheet->writeStr (0, i, UNISTR_TO_LIBXLSTR (titles));
GS::Array<API_Guid> apiguids;
ACAPI_Element_GetElemList (API_WallID, &apiguids);
for (UIndex i = 0; i < apiguids.GetSize (); ++i) {
GS::Guid gsguid = APIGuid2GSGuid (apiguids);
API_Element element = {};
element.header.guid = apiguids;
GSErrCode err = ACAPI_Element_Get (&element);
if (err != NoError) {
DBPrintf ("ACAPI_Element_Get returned error (%d) for GUID '%s'\n", err,
gsguid.ToUniString ().ToCStr ().Get ());
continue;
API_WallType& wall = element.wall;
//DBPrintf ("GUID '%s'\n", gsguid.ToUniString ().ToCStr ().Get ());
sheet->writeStr (i + 1, 0, UNISTR_TO_LIBXLSTR (gsguid.ToUniString ()), guidFormat);
sheet->writeNum (i + 1, 1, wall.height);
sheet->writeNum (i + 1, 2, wall.begC.x);
sheet->writeNum (i + 1, 3, wall.begC.y);
sheet->writeNum (i + 1, 4, wall.endC.x);
sheet->writeNum (i + 1, 5, wall.endC.y);
IO::Location location;
IO::fileSystem.GetSpecialLocation (IO::FileSystem::UserDocuments, &location);
location.AppendToLocal (IO::Name ("export.xlsx"));
GS::UniString filepath;
location.ToPath (&filepath);
DBASSERT (book->save (UNISTR_TO_LIBXLSTR(filepath)));
book->release ();
DBPrintf ("Export operation finished\n");
code for GSException.hpp file
// Class GSException
// Module: GSRoot
// Namespace: GS
// Contact person: MB, FGY, MM
// SG compatible
#ifndef GSEXCEPTION_HPP
#define GSEXCEPTION_HPP
#pragma once
#include <stdio.h>
#include <exception>
#include <new>
#include "GSRootExport.hpp"
#include "Definitions.hpp"
#include "GSDebug.hpp"
namespace GS { class ClassInfo; }
namespace GS { class OChannel; }
namespace GS { class UniString; }
#include "StackInfo.hpp"
// Undefine Windows Macros, we want to use "GetMessage"
#if defined (WINDOWS)
#if defined (GetMessage)
#undef GetMessage
#endif
#endif
// ============================== Class GSException ==============================
#define GS_EXCEPTIONS_DLL_EXPORTED
namespace GS {
#define GS_EXCEPTIONS_INLINE
#define GS_EXCEPTIONS_GSROOT_DLL_EXPORT GSROOT_DLL_EXPORT
class GSROOT_DLL_EXPORT GSException {
// DECLARE_DYNAMIC_CLASS
public:
typedef StackInfoCustomDepth<128> StackInfo;
private:
static constexpr USize AlignOfUniString = alignof (void*);
static constexpr USize SizeOfUniString = 2 * sizeof (void*);
Int32 id; // this is the equivalent error id (it is the same for the given type of exception)
GS::UniString& message; // additional message for the exception from the thrower (if it isn't nullptr)
alignas (AlignOfUniString) char messageStorage[SizeOfUniString];
const char* fileName; // name of file where the exception was thrown from (if it isn't nullptr)
UInt32 lineNumber; // line number where the exception was thrown from (if it isn't 0)
GSException* cause; // exception chaining
GSException::StackInfo stackInfo;
void SetCause (const GSException* cause);
void SetCause (const GSException& cause);
public:
// Constructors
explicit GSException (const char* message = nullptr,
const char* fileName = nullptr,
UInt32 lineNumber = 0,
const GSException* cause = nullptr,
Int32 id = 0 // should be wired in all of the derived classes
explicit GSException (const char* message,
const char* fileName,
UInt32 lineNumber,
const GSException& cause,
Int32 id // should be wired in all of the derived classes
explicit GSException (const GS::UniString& message,
UInt32 lineNumber,
GSException (const GSException& source);
virtual ~GSException () throw ();
// User interface
void SetMessage (const GS::UniString& message);
void SetMessage (const char* message);
virtual const char* GetName (void) const;
virtual Int32 GetID (void) const;
virtual const GS::UniString& GetMessage (void) const;
virtual const char* GetFileName (void) const;
virtual UInt32 GetLineNumber (void) const;
virtual GSException* Clone (void) const;
virtual void Print (OChannel& oc) const;
virtual void Dump (OChannel& oc) const;
virtual const GSException* GetCause () const;
virtual GSException* GetCause ();
virtual const StackInfo& GetStack () const;
GSException& operator= (const GSException& source);
extern const GSROOT_DLL_EXPORT GSException NoCauseException; // Special value used when there's no cause of the exception
typedef GSException Exception; // GS::Exception
// ______________________________ Class GSException ______________________________
// ======================= GSException hierarchy framework =======================
class GS_EXCEPTIONS_GSROOT_DLL_EXPORT RootException : virtual public GSException {
public:
explicit RootException (const char* msg, const char* fName, UInt32 lNumber, const GSException& cause_) :
GSException (msg, fName, lNumber, cause_, (Int32)Error)
explicit RootException (const char* msg = nullptr, const char* fName = nullptr, UInt32 lNumber = 0) :
GSException (msg, fName, lNumber, nullptr, (Int32)Error)
explicit RootException (const GS::UniString& msg, const char* fName, UInt32 lNumber, const GSException& cause_) :
explicit RootException (const GS::UniString& msg, const char* fName = nullptr, UInt32 lNumber = 0) :
virtual const char* GetName () const override;
virtual GSException* Clone (void) const override;
class GS_EXCEPTIONS_GSROOT_DLL_EXPORT GeneralException : virtual public GSException {
public:
explicit GeneralException (const char* msg, const char* fName, UInt32 lNumber, const GSException& cause_) :
explicit GeneralException (const char* msg = nullptr, const char* fName = nullptr, UInt32 lNumber = 0) :
explicit GeneralException (const GS::UniString& msg, const char* fName, UInt32 lNumber, const GSException& cause_) :
explicit GeneralException (const GS::UniString& msg, const char* fName = nullptr, UInt32 lNumber = 0) :
#define DECLARE_EXCEPTION_CLASS_WITH_CLASS_SPEC(classSpec, className, baseClassName, errId) \
class classSpec: virtual public baseClassName { \
public: \
explicit className (const char* msg, const char* fName, UInt32 lNumber, const GS::GSException& cause); \
explicit className (const char* msg = nullptr, const char* fName = nullptr, UInt32 lNumber = 0); \
explicit className (const GS::UniString& msg, const char* fName, UInt32 lNumber, const GS::GSException& cause); \
explicit className (const GS::UniString& msg, const char* fName = nullptr, UInt32 lNumber = 0); \
virtual const char* GetName () const override; \
virtual GS::GSException* Clone (void) const override; \
#define DECLARE_EXCEPTION_CLASS(className, baseClassName, errId, exportdef) \
DECLARE_EXCEPTION_CLASS_WITH_CLASS_SPEC(exportdef className, className, baseClassName, errId)
#define DECLARE_EXCEPTION_CLASS_NO_EXPORTDEF(className, baseClassName, errId) \
DECLARE_EXCEPTION_CLASS_WITH_CLASS_SPEC(className, className, baseClassName, errId)
#define IMPLEMENT_EXCEPTION_CLASS_WITH_NAMESPACE(classNameWithNamespace, className, baseClassName, errId) \
classNameWithNamespace::className (const char* msg, const char* fName, UInt32 lNumber, const GS::GSException& cause): \
GS::GSException (msg, fName, lNumber, cause, errId), baseClassName () {} \
classNameWithNamespace::className (const char* msg, const char* fName, UInt32 lNumber): \
GS::GSException (msg, fName, lNumber, nullptr, errId), baseClassName () {} \
classNameWithNamespace::className (const GS::UniString& msg, const char* fName, UInt32 lNumber, const GS::GSException& cause): \
classNameWithNamespace::className (const GS::UniString& msg, const char* fName, UInt32 lNumber): \
const char* classNameWithNamespace::GetName () const { return #className; } \
GS::GSException* classNameWithNamespace::Clone (void) const { return new className (*this); }
#define IMPLEMENT_EXCEPTION_CLASS(className, baseClassName, errId) \
IMPLEMENT_EXCEPTION_CLASS_WITH_NAMESPACE (className, className, baseClassName, errId)
#define DECLARE_EXCEPTION_CLASS2(className, baseClassName1, baseClassName2, errId, exportdef) \
class exportdef className: virtual public baseClassName1, virtual public baseClassName2 { \
public: \
#define IMPLEMENT_EXCEPTION_CLASS2(className, baseClassName1, baseClassName2, errId) \
className::className (const char* msg, const char* fName, UInt32 lNumber, const GS::GSException& cause): \
GS::GSException (msg, fName, lNumber, cause, errId), baseClassName1 (), baseClassName2 () {} \
className::className (const char* msg, const char* fName, UInt32 lNumber): \
GS::GSException (msg, fName, lNumber, nullptr, errId), baseClassName1 (), baseClassName2 () {} \
className::className (const GS::UniString& msg, const char* fName, UInt32 lNumber, const GS::GSException& cause): \
className::className (const GS::UniString& msg, const char* fName, UInt32 lNumber): \
const char* className::GetName () const { return #className; } \
GS::GSException* className::Clone (void) const { return new className (*this); }
DECLARE_EXCEPTION_CLASS (LogicErrorException, GeneralException, Error, GSROOT_DLL_EXPORT)
DECLARE_EXCEPTION_CLASS (PreconditionException, LogicErrorException, ErrParam, GSROOT_DLL_EXPORT)
DECLARE_EXCEPTION_CLASS (IllegalArgumentException, PreconditionException, ErrParam, GSROOT_DLL_EXPORT)
DECLARE_EXCEPTION_CLASS (IllegalReferenceException, IllegalArgumentException, ErrParam, GSROOT_DLL_EXPORT)
DECLARE_EXCEPTION_CLASS (NullPointerException, IllegalArgumentException, ErrParam, GSROOT_DLL_EXPORT)
DECLARE_EXCEPTION_CLASS (NullReferenceException, IllegalArgumentException, ErrParam, GSROOT_DLL_EXPORT)
DECLARE_EXCEPTION_CLASS (NullHandleException, IllegalArgumentException, ErrParam, GSROOT_DLL_EXPORT)
DECLARE_EXCEPTION_CLASS (EmptyHandleException, IllegalArgumentException, ErrParam, GSROOT_DLL_EXPORT)
DECLARE_EXCEPTION_CLASS (IllegalTypeException, IllegalArgumentException, ErrParam, GSROOT_DLL_EXPORT)
DECLARE_EXCEPTION_CLASS (RunTimeErrorException, GeneralException, Error, GSROOT_DLL_EXPORT)
DECLARE_EXCEPTION_CLASS (AccessViolationException, RunTimeErrorException, Error, GSROOT_DLL_EXPORT)
DECLARE_EXCEPTION_CLASS (LimitViolationException, RunTimeErrorException, Error, GSROOT_DLL_EXPORT)
DECLARE_EXCEPTION_CLASS (ConversionErrorException, RunTimeErrorException, Error, GSROOT_DLL_EXPORT)
DECLARE_EXCEPTION_CLASS (InternalErrorException, RunTimeErrorException, Error, GSROOT_DLL_EXPORT)
DECLARE_EXCEPTION_CLASS (IllegalStateException, RunTimeErrorException, Error, GSROOT_DLL_EXPORT)
DECLARE_EXCEPTION_CLASS (UnsupportedOperationException, RunTimeErrorException, Error, GSROOT_DLL_EXPORT)
DECLARE_EXCEPTION_CLASS2 (OutOfMemoryException, RunTimeErrorException, std::bad_alloc, ErrMemoryFull, GSROOT_DLL_EXPORT)
// General implementation of the precondition
#define PRECOND_IMP(preCondition, exception) \
if (!(preCondition)) { \
DBBREAK (); \
throw exception (nullptr, __FILE__, __LINE__); \
// Preconditions that will be compiled only into the debug and test versions
#define PRECOND(condition) DBASSERT(condition)
#define ARG_CHECK(condition) DBASSERT(condition)
#define REF_CHECK(condition) DBASSERT(condition)
#define NULL_PTR_CHECK(ptr) DBASSERT(ptr != nullptr)
#define NULL_REF_CHECK(ref) DBASSERT(&ref != nullptr)
#define TYPE_CHECK(condition) DBASSERT(condition)
// Preconditions that will always be compiled (debug, test and release)
#define PRECOND_R(condition) PRECOND_IMP(condition, GS::PreconditionException)
#define ARG_CHECK_R(condition) PRECOND_IMP(condition, GS::IllegalArgumentException)
#define REF_CHECK_R(condition) PRECOND_IMP(condition, GS::IllegalReferenceException)
#define NULL_PTR_CHECK_R(ptr) PRECOND_IMP(ptr != nullptr, GS::NullPointerException)
#define NULL_REF_CHECK_R(ref) PRECOND_IMP(&ref != nullptr, GS::NullReferenceException)
#define TYPE_CHECK_R(condition) PRECOND_IMP(condition, GS::IllegalTypeException)
// _______________________ GSException hierarchy framework _______________________
#endif
Solved! Go to Solution.
2018-12-15 10:01 AM
2018-12-06 10:40 AM
2018-12-07 03:55 PM
2018-12-15 10:01 AM
2018-12-17 02:35 AM
2018-12-20 08:18 AM
