‎2019-10-03
06:09 AM
‎2022-09-29
10:10 AM
Daniel Kassai
Solved! Go to Solution.
‎2019-10-11 09:33 AM
‎2019-10-08 10:48 AM
poco2013 wrote:If you register a menu item, by default it will be enabled only when the 2D Floor Plan window is active. If you switch to 3D window or a Layout window, your menu item will be disabled (grayed out).
The DG_Test menu item appends a '^EL' onto the end of the menu items. The instructions read:
"^EL The command is enabled above layout and master layout windows "
But I have no idea what that means
‎2019-10-08 01:09 PM
‎2019-10-11 11:18 AM
