API : HotlinkNode Element and database
Hello,
i'm trying since last month to write a plugin which load an external Hotlinked Module and place it on the project.
I'm near the end , i'v loaded the module, assigned it to an element but i don't succeed to place it on the project.
Here is my little fonction :
API_HotlinkNode myAPI_HotlinkNode;
	GSErrCode err;
	IO::Location  location("c:\\test.MOD");
	API_Guid myAPI_HotlinkNodeGuid;
	API_Element element;
	API_ElementMemo memo;
/******************************REMPLISSAGE DE LA STRUCTURE******************************************/
	BNZeroMemory (&myAPI_HotlinkNode, sizeof (API_HotlinkNode));
	//Charge le module en mode unique (define single story mode)
	myAPI_HotlinkNode.storyRangeType = APIHotlink_SingleStory;
	//Precise les que les extensions possibles sont :.pln, .mod, .plp or .2dl file. (define file type)
	myAPI_HotlinkNode.type = APIHotlink_Module;
	//Définie le fichier à charger (define file to load)
	myAPI_HotlinkNode.sourceLocation = &location;
	//definie l'étage comme étant l'étage -2
	myAPI_HotlinkNode.refFloorInd = -2;
	CHANSI2Unicode ("Module 1", GS::CStringLen, myAPI_HotlinkNode.name,API_UniLongNameLen, CC_Default, NULL);
/******************************FIN REMPLISSAGE DE LA STRUCTURE**************************************/
/********************CREATION DU GUID*************************************/
	err = ACAPI_Database (APIDb_CreateHotlinkNodeID,&myAPI_HotlinkNode,NULL,NULL);
	if (err != NoError) {
			afficheMessage("HotlinkNode parameter is NULL or sourceLocation is NULL or invalid",err);
			return err;
	myAPI_HotlinkNodeGuid = myAPI_HotlinkNode.guid;
/********************MISE A JOUR DU CACHE*********************************/
	err = ACAPI_Database (APIDb_UpdateHotlinkCacheID,&myAPI_HotlinkNodeGuid,NULL,NULL);
			switch(err)
			case APIERR_BADPARS:
								afficheMessage("hotlinkNodeGuid parameter is NULL",err);
								break;
			case APIERR_BADID:
								afficheMessage("hotlinkNodeGuid is invalid",err);
								break;
			default:
					afficheMessage("APIDb_UpdateHotlinkCacheID",err);
					break;
			return err;
/******************PLACE LE MODULE LIE DANS LA DATABASE*******************/
err = ACAPI_OpenUndoableSession ("Place le module");
if (err == NoError)
	BNZeroMemory (&element, sizeof (API_Element));
	element.header.typeID = API_HotlinkID ;
	element.header.index = 1;
	err = ACAPI_Element_GetDefaults (&element, &memo);
	if (err == NoError)
		element.hotlink.type = APIHotlink_Module;
		element.hotlink.hotlinkNodeGuid = myAPI_HotlinkNodeGuid;
		err = ACAPI_Element_Create(&element, &memo);
		if (err != NoError)
			switch(err)
									afficheMessage("The passed parameter is NULL; element",err);
									break;
				case APIERR_BADID:
									afficheMessage("The element type is invalid, or the element type is not supported by the server application",err);
									break;
				case APIERR_BADDATABASE:
									afficheMessage("The current database is not proper for the operation",err);
									break;
				case APIERR_REFUSEDPAR:
									afficheMessage("The element->header.typeID parameter was incorrect. It might happen if you want to create something in a window not capable to display it, for example a wall in a section window. ",err);
									break;
				case APIERR_NOTMINE:
									afficheMessage("The element was attempted to be created on a layer owned by someone else. Most likely to occur when working on documents in teamwork mode. ",err);
									break;
				case APIERR_LOCKEDLAY:
									afficheMessage("The element attempted to be created was on a locked layer",err);
									break;
				case APIERR_HIDDENLAY:
									afficheMessage("The element attempted to be created was on a hidden layer.",err);
									break;
				case APIERR_INVALFLOOR:
									afficheMessage("The element->header.floorInd parameter is out of range.",err);
									break;
				case APIERR_REFUSEDCMD:
									afficheMessage("The passed identifier is not subject to the operation.",err);
									break;
				default:
						afficheMessage("ACAPI_Element_Create",err);
						break;
			return err;
		err = ACAPI_Database (APIDb_RedrawCurrentDatabaseID,NULL,NULL,NULL);
		if (err != NoError)
			afficheMessage("APIDb_RedrawCurrentDatabaseID",err);
		ACAPI_DisposeElemMemoHdls (&memo);
	else
		afficheMessage("ACAPI_Element_GetDefaults",err);
	ACAPI_CloseUndoableSession();
else
	afficheMessage("ACAPI_OpenUndoableSession",err);
if someone would know the thing i forgot to do, thank you in advance for your help.
8 Replies 8
atila-diffusion wrote:
Hello,
Is an error returned at any point in this function? If so, where, and which error code?
Ralph Wessel BArch
Central Innovation
Hello,
not any error is returned, that's why I really don't know what is missing.
Check the easy things first - have you checked the storey (floor) and layer applied? And what does the transformation matrix contain?
Ralph Wessel BArch
Central Innovation
I allready checked the floor, but i do not filled the transformation matrix, I thought it was not needed.
Do I have to fill it like this :
element.hotlink.transformation.tmx[3] = 10;
			element.hotlink.transformation.tmx[7] = 4;
			double	co = cos (0.52359877556);
			double	si = sin (0.52359877556);
			element.hotlink.transformation.tmx[0] = element.hotlink.transformation.tmx[5] = co;
			element.hotlink.transformation.tmx[1] = -si;
			element.hotlink.transformation.tmx[4] = si;
about the layer is it this :
element.header.layer = 1;
THANK YOU VERY MUCH .
It works thanks to you, had to fill the layer.
I thank you very much.
Do you know if we have to ask for a validation to graphisoft before to sell a plugin, or to do something else?
Yes, you need a developer ID from Graphisoft to enable the add-on to work with the commercial version of ArchiCAD. Take a look at the information here: http://www.graphisoft.com/support/developer/policy/index.html
Ralph Wessel BArch
Central Innovation
Ok thank you I already asked for an ID. i'm waiting for it.
Thank you for all
