2021-04-21
08:31 PM
- last edited on
2021-09-14
09:40 AM
by
Noemi Balogh
// change params here
GS::UniString newtxt("XXX");
API_ChangeParamType chgParam;
API_ParamOwnerType paramOwner;
API_GetParamsType getParams;
BNZeroMemory(&chgParam, sizeof(API_ChangeParamType));
BNZeroMemory(¶mOwner, sizeof(API_ParamOwnerType));
BNZeroMemory(&getParams, sizeof(API_GetParamsType));
paramOwner.libInd = libIndex;
paramOwner.typeID = API_ObjectID; /* object element */
paramOwner.guid = APINULLGuid;
ACAPI_Goodies(APIAny_OpenParametersID, ¶mOwner,nullptr);
err = ACAPI_Goodies(APIAny_GetActParametersID, &getParams, nullptr);
if(err == NoError){
chgParam.index = libIndex;
CHCopyC("txt", chgParam.name);
GS::ucscpy(chgParam.uStrValue.uStr, newtxt.ToUStr()); //exception here
chgParam is incorrect -- getting message error "left of uStr must have class/struct/union" - I have changed ucsscpy all different ways and can't get it right.
err = ACAPI_Goodies(APIAny_ChangeAParameterID, &chgParam,nullptr);
ACAPI_Goodies(APIAny_CloseParametersID,nullptr,nullptr);
if (err)
ACAPI_WriteReport("busted",true);
EDIT:: found the answer here -- viewtopic.php?f=23&t=68038 Thanks Tibor However, using above with correction - still can't get string parameter to change?? Add-On runs with no errors but no change now.Solved! Go to Solution.
2021-04-27 11:02 PM
API_GetParamsType theParams = {};
API_ParamOwnerType paramOwner = {};
GS::uchar_t uStrBuffer[BUFFER_SIZE];
paramOwner.libInd = libPartIndex;
GSErrCode err = ACAPI_Goodies (APIAny_OpenParametersID, ¶mOwner);
err |= ACAPI_Goodies (APIAny_GetActParametersID, &theParams);
if (err == NoError) {
API_ChangeParamType changeParam = {};
CHTruncate (paramName, changeParam.name, API_NameLen);
GS::ucsncpy (uStrBuffer, newStrValue.ToUStr ().Get (), BUFFER_SIZE);
changeParam.uStrValue = uStrBuffer;
err = ACAPI_Goodies (APIAny_ChangeAParameterID, &changeParam);
// Do something with theParams.params
ACAPI_DisposeAddParHdl (&theParams.params);
ACAPI_Goodies (APIAny_CloseParametersID);
I'm here to help, but at first I have to know what's your purpose...API_ElementMemo memo = {};
memo.params = theParams.params;
API_Element mask;
ACAPI_ELEMENT_MASK_CLEAR (mask);
API_Element elem = {};
elem.header.guid = elemGuid;
ACAPI_Element_Get (&elem);
err = ACAPI_Element_Change (&elem, &mask, &memo, APIMemoMask_AddPars, true);
Or you would like to change the default value of the parameter in a library part? To achieve that, you have to overwrite the library part in the library.
2021-04-27 11:02 PM
API_Element mask;
2021-04-28 12:13 AM
