APIERR_BADINDEX getting element
I've found on several drawings in ArchiCAD 9 an ACAPI_Element_Get returns APIERR_BADINDEX. Just wondering how this could happen? It doesn't happen in ArchiCAD 7.
Here is what my code is doing:
ACAPI_Element_GetNum(API_TextID, &num);
for(ii=1;ii<=num;++ii)
   if(ACAPI_Element_Filter(API_TextID, ii, APIFilt_IsEditable))
      memset(&element, 0, sizeof(API_Element));
      element.header.index = ii;
      element.header.typeID = API_TextID;
      err = ACAPI_Element_Get(&element);
      if(err == APIERR_BADINDEX)
            // this is true when ii==num which should be a valid index, shouldn't it ?
2 Replies 2
The number returned by ACAPI_Element_Get is the highest index used in the database, which is not necessarily the number of elements in the database. The documentation states:
Please note that the returned number does not necessarily match the number of existing elements of that type, as the ArchiCAD database may contain deleted elements as well; see the ACAPI_Element_Filter function for more details.
Ralph Wessel BArch
Central Innovation
My concern is that I am filtering the elements, so this element with a bad index is not deleted. I think I will have to go through my code and 'continue' if I get a badindex result from an ACAPI_Element_Get
Thanks,
Adam
