poco2013
Mentor
Add-On Template
The Xcode Add On Template is great to get started but lacks the menu 'hook-up' necessary to start a project. This kind of defeats the propose of a quick start template.
Would like to see a template that includes a simple test menu with say one item/function and the standard 'Hello World' WriteReport message.
Are there any instruction available as how to create my own template in xcode to do this?
Gerry
1 Solution
Akos Somorjai
Hai wrote:
Hi Ralph,
Thank you so much but I'm a beginner and sorry I don't understand where menu handler is.
So, in your RegisterInterface() function:
GSErrCode	__ACENV_CALL	RegisterInterface (void)
	ACAPI_Register_Menu (32500, 0, MenuCode_UserDef, MenuFlag_Default);
	return NoError;
}		// RegisterInterface
Here 32500 is the ID of the string resource that appears in the menu; add this to the .grc file:
'STR#' 32500 "Strings for the Menu" {
/* [  1] */  "Hello world"
Then in your Initialize() function add the following:
GSErrCode __ACENV_CALL	Initialize (void)
    GSErrCode err = ACAPI_Install_MenuHandler (32500, MenuCommandHandler);
    // other stuff
Last, in your MenuCommandHandler function call Do_CreateHelloWord():
GSErrCode	__ACENV_CALL	MenuCommandHandler (const API_MenuParams *params)
    if (params->menuItemRef.itemIndex == 1) {
        Do_CreateHelloWord ();
Go to post
8 Replies 8
It would be good to have one for Visual Studio as well. So you can start project instantly on custom path.
I'm using VS 2017 but I don't know how to start with Hello World Blog. How can I use that code and necessary resource to get Hello World in AC. Could you show me how to do it step by step? Thanks for your kind.
I suggest copying one of the example projects with a single menu item, e.g. AddOnObject_Manager and replace the code in the menu handler:
// DoCommand
//		called to perform the user-asked command
		//Your code here
	return NoError;
}		// MenuCommandHandler
Ralph Wessel BArch
Central Innovation
Hi Ralph,
Search the project for MenuCommandHandler. For that particular project, it's in the file AddOnObject_Manager.cpp
Ralph Wessel BArch
Central Innovation
Akos Somorjai
Hai wrote:
Hi Ralph,
	return NoError;
    // other stuff
Thank you very much. I will learn it and reply for result as soon.
Hi Akos,
Thank you very much for the detailed guide for me. It's very helpful for the beginner like me.
P/S: Thanks for Ralph, I can build more example without any errors and maybe I knew how API work and folder structure. Thank so much for supporting. I will do something by myself ^.^
