Add-On wizard (DevKit 19) generates un-compilable code
Hello, I'm new to the world of AC add-on development so please bear with me and sorry if this question has been addressed elsewhere... (i searched the best i could)
I managed to compile the example add-ons with VS2010, and successfully ran them in AC19
As i like to start with a clean slate, i took a look over the Add-On Wizard. Here are the build errors i get...
1>------ Build started: Project: ACAddOn1, Configuration: Debug x64 ------
1>Build started 2015-09-29 3:07:13 PM.
1>InitializeBuildStatus:
1>  Touching "x64\\ACAddOn1.unsuccessfulbuild".
1>CustomBuild:
1>  All outputs are up-to-date.
1>ClCompile:
1>  ACAddOn1.cpp
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(54): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(54): error C2143: syntax error : missing ',' before '*'
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(55): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(55): error C2143: syntax error : missing ',' before '*'
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(84): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(84): error C2143: syntax error : missing ';' before '*'
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(85): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(85): error C2143: syntax error : missing ';' before '*'
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(86): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(86): error C2143: syntax error : missing ';' before '*'
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(87): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(87): error C2143: syntax error : missing ';' before '*'
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(88): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(88): error C2143: syntax error : missing ';' before '*'
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(89): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(89): error C2143: syntax error : missing ';' before '*'
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(90): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(90): error C2143: syntax error : missing ';' before '*'
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(91): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(91): error C2143: syntax error : missing ';' before '*'
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(92): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(92): error C2143: syntax error : missing ';' before '*'
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(93): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(93): error C2143: syntax error : missing ';' before '*'
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(94): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(94): error C2143: syntax error : missing ';' before '*'
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(95): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(95): error C2143: syntax error : missing ';' before '*'
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(96): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(96): error C2143: syntax error : missing ';' before '*'
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(97): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(97): error C2143: syntax error : missing ';' before '*'
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(98): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(98): error C2143: syntax error : missing ';' before '*'
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(99): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(99): error C2143: syntax error : missing ';' before '*'
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(100): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(100): error C2143: syntax error : missing ';' before '*'
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(113): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(113): error C2143: syntax error : missing ',' before '*'
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(161): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(161): error C2143: syntax error : missing ',' before '*'
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(163): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(163): error C2143: syntax error : missing ',' before '*'
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(164): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(164): error C2143: syntax error : missing ',' before '*'
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(187): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\program files\graphisoft\api development kit 19.3003\support\modules\gsroot\RS.hpp(187): error C2143: syntax error : missing ',' before '*'
1>C:\Program Files\GRAPHISOFT\API Development Kit 19.3003\Support\Inc\ACAPinc.h(123): error C2143: syntax error : missing ';' before '__cdecl'
1>C:\Program Files\GRAPHISOFT\API Development Kit 19.3003\Support\Inc\ACAPinc.h(123): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\GRAPHISOFT\API Development Kit 19.3003\Support\Inc\ACAPinc.h(125): error C2143: syntax error : missing ';' before '__cdecl'
1>C:\Program Files\GRAPHISOFT\API Development Kit 19.3003\Support\Inc\ACAPinc.h(125): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files (x86)\Microsoft SDKs\Windows\v7.0A\include\prsht.h(97): error C2065: 'CALLBACK' : undeclared identifier
1>C:\Program Files (x86)\Microsoft SDKs\Windows\v7.0A\include\prsht.h(97): error C2065: 'LPFNPSPCALLBACKA' : undeclared identifier
1>C:\Program Files (x86)\Microsoft SDKs\Windows\v7.0A\include\prsht.h(97): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files (x86)\Microsoft SDKs\Windows\v7.0A\include\prsht.h(97): fatal error C1903: unable to recover from previous error(s); stopping compilation
1>
1>Build FAILED.
1>
1>Time Elapsed 00:00:01.96
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Some of the missing types are "WCHAR", "HINSTANCE", "HWND"... the funny thing is that when I try to find the definitions using VS2010 "find definition" function it finds them....
Any help is greatly appreciated!
While the issue with the Archicad AddOn Wizard is solved by its developers, consider this workaround.
Akos Somorjai
1>CustomBuild:
1>ClCompile:
1>  ACAddOn1.cpp
1>
1>Build FAILED.
1>
Please add an #include <windows.h> to the include section in the .cpp file.
Best, Akos
