Add context menu to a DG control?
How can I add a context menu to a DG control, to a LeftText for example?
I found it:
void AddMenuItem (DG::Menu& menu, int id, std::string text)
	DG::CommandDescriptor* commandDescriptor =
		new DG::CommandDescriptor (DG::Command (id), text.c_str ());
	menu.AddMenuItem (DG::MenuSimpleItem (commandDescriptor));
void MyPalette::ItemContextMenuRequested (
	const DG::ItemContextMenuEvent& ev, bool* needHelp, bool* processed)
	*processed = true;
	DG::Menu* menu = new DG::Menu ("");
	AddMenuItem (*menu, 1, "Apple");
	AddMenuItem (*menu, 2, "Pear");
	AddMenuItem (*menu, 3, "Dog");
	DG::CommandEvent& commandEvent = *DG::ContextMenu ("", menu).Display (ev.GetPosition ());
	if (&commandEvent != 0)
		std::stringstream stream;
		stream << "Clicked ";
		stream << commandEvent.GetCommand ().GetCommandId ();
		DGAlert (DG_INFORMATION, "Apple", stream.str ().c_str (), NULL, "OK", NULL, NULL);
My problem now is when to call the destructors.
