Archicad C++ API
Add-on error
RAFD
Hi, I just want to ask what I should do if my archicad 27 always crashes while opening an add-on made by our company? It's working perfectly in AC26. I manage to upgrade the add-on for AC27 but when I try to open it, it crashes.
4 REPLIES 4
LChen
Hi, If API27 example addon works on your PC without any problem, then I'd suggest you to check VC project file settings carefully to see whether everything (include header/lib/etc. file path) refer to new API27 Dev Kit and try again.
HTH.
There can be a lot of different reasons for this. I'd try the following approach to debug your Add-On:
  1. Remove the Add-On from the Add-On Manager
  2. Restart Archicad
  3. Attach a debugger to Archicad
  4. Set breakpoints at the start of the CheckEnvironment, RegisterInterface and Initialize functions
  5. Load the Add-On and step through the code to see when it crashes
  6. Alternatively check the stack trace when it crashes
Hope that helps,
Bernd
RAFD
Hi @BerndSchwarzenbacher I tried your solution, but it stopped when AC27 opened, it didn't crash or open the add-on, and no errors is found.
What stopped when AC27 opened?
Do you mean you've hit a breakpoint or something else?
