Archicad C++ API
An unhandled exception was encountered during a user callbac
Hello
I call dll functions from my ac add-on.
Archicad crashs end of the code!
I get the following error
'Unhandled exception at 0x00007ff8eacc6a20 in ArchiCAD.exe: 0xC000041D: An unhandled exception was encountered during a user callback'
and here is my code
 if (e.GetSource() == &m_btnTest) {
		typedef IKlass* (__cdecl *iklass_factory)();
		HINSTANCE dll_handle = ::LoadLibrary(TEXT("BCWebSDK.dll"));
		if (!dll_handle) {
		// Get the function from the DLL
		iklass_factory factory_func = reinterpret_cast<iklass_factory>(::GetProcAddress(dll_handle, "create_klass"));
		if (!factory_func) {
			::FreeLibrary(dll_handle);
		IKlass* instance = factory_func();
		std::vector<int> info = instance->data(); //  This is what I need from dll and it works fine
		instance->destroy();
I get data which I need but end of the code archicad crashs
The same code works in other projects so error occurs only when I try to run my code in archicad add-on
and mouse pointer goes to GSNew.hpp file on delete function
Thanks in advance!
1 REPLY 1
BrunoValads
Hi! Were you able to fix this error? I'm getting the same exception when using libcpr (DLLss are in Archicad.exe folder, and LIBs are properly linked at "Aditional Dependencies").
