Ed_Brown
Graphisoft Alumni
Graphisoft Alumni
ArchiCAD 9 Developer Tools Available for Download
Developer tools for ArchiCAD 9 are available for download. Please find detailed information and new feature list together with the tools to download at http://www.graphisoft.com/support/developer/. It is important to note that new compilers (CodeWarrior 9, .NET 2003) have to be used for creating Add-Ons compatible with ArchiCAD 9.
Graphisoft Technical Support
9 Replies 9
Ben Cohen
Hi Ed
Any idea when the ODBC drivers for version 9 will be released?
Cheers
Ben
Ben Cohen
Mac and PC
Archicad (Latest Version) aus
www.4DLibrary.com.au
Ed_Brown
Graphisoft Alumni
Graphisoft Alumni
To Ben and all others waiting patiently for the ODBC driver.
The updated driver is now available at http://www.graphisoft.com/support/developer/.
Sorry for the delay,
Ed
Hi , I've downloaded the ArchiCAD 9 API.
I asked for Visual Studio 2003 , but was given Visual Studio 2005.
Visual Studio 2005 converts the solutions OK, but can n't compile the resources. The following from DLL Test, but also tried another example and get stopped at the same point.
Error 1 fatal error RC1015: cannot open include file 'Dll_Test.grc.rc2'. c:\Program Files\Graphisoft\API Development Kit 6.1\Examples\Dll_Test\RFIX.WIN\Dll_Test.rc2 19
Error 2 error PRJ0019: A tool returned an error code from "Compiling the RC2 file..." Dll_Test
Has anyone used Visual Studion 2005 with the ArchiCAD 9 Developer Tools ?
Todd
Sorry, but I have the same problem while developing with DevKit 12 using MSVC8.
I was build some DevKit Examples successfully with my developing ID and load it to ArchiCAD 12.
Then I was create a new ArchiCAD Add-On project and just try to compile it.
The next error occur:
------ Rebuild All started: Project: ArchiCAD Add-On2, Configuration: Debug Win32 ------
Deleting intermediate and output files for project 'ArchiCAD Add-On2', configuration 'Debug|Win32'
External build tool process set to low priority...
d:\work\archicad\ArchiCAD Add-On2\ArchiCAD Add-On2\Make.Win\..\RFIX.WIN\ArchiCADAddOn2.rc2(15) : fatal error RC1015: cannot open include file '..\Debug\ArchiCADAddOn2.grc.rc2'.
Project : error PRJ0019: A tool returned an error code from "Compiling the RC2 file..."
Creating browse information file...
Microsoft Browse Information Maintenance Utility Version 8.00.50727
Copyright (C) Microsoft Corporation. All rights reserved.
BSCMAKE: error BK1506 : cannot open file '.\debug\ArchiCADAddOn2.sbr': No such file or directory
Build Time 0:00
Build log was saved at "file://d:\work\archicad\ArchiCAD Add-On2\ArchiCAD Add-On2\Make.Win\Debug\BuildLog.htm"
ArchiCAD Add-On2 - 3 error(s), 0 warning(s)
========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
Please, show me my error.
Sounds like the project template (used for New Project) does not have the proper settings for invoking the resource compiler. And/or you saved the project somewhere else on your disk and the project settings use relative paths, such as ../.. to find things.
First, try copying your entire new project folder to be inside the Examples folder. If that builds, then it is indeed just an issue of the build settings using relative paths.
If that still does not work, then since the examples build for you, just copy and example, and replace the source files for it with yours and go from there....unless you feel like digging into all of the build settings to track it down the problem...
Thanks, Karl
You're welcome ... please post what eventually solves the problem for you.
Thanks,
Oh, sorry.
I use example project as base for my Add-On.
I just tried to compile the 64-bit version of my add-on and it doesnt work. Im using MSVC 2005 and devKit 13 (latest).
If I compile the 32-bit version, everything goes right, build succeeds and add-on is working.
But when I switch the libraries to x64 and switch the compiler to x64, it stops on the error mentioned previously:
"fatal error RC1015: cannot open include file 'Selection_Manager.grc.rc2'." and so on.
Any idea where the problem could be? Thanks
Peter
I tried clean devkit examples: it is the same - win32 compiling ok, x64 with 64bit libraries has error
