ArchiCAD Add-on with Excel File
I found this article from Codeproject and I want merge it with ArchiCAD-Addon
http://www.codeproject.com/KB/office/ExcelFormat.aspx?fid=1549560&fr=76&df=90&mpp=25&noise=3&sort=Po...
in TestExcel Folder it's can complie and use the library successfully.
But when I cut the snippet code to merge with ArchiCAD. It can compile successfully. But in run-time when I use command. It's show ASSERTION ERROR at dbgdel.cpp file at line 52 and ArchiCAD is crash too.
How can I merge this library to add-on?
Could you help me solve the problem?
1 Reply 1
I just found that I can run it with release mode. It's has no assertion error
But in Debug mode. It's Assertion error.
I include file below.
