		2019-09-21
		07:12 AM
		2022-09-29
		10:16 AM
			Daniel Kassai
Solved! Go to Solution.
2019-09-26 09:19 AM
2019-09-22 12:02 AM
2019-09-23 09:18 AM
2019-09-23 01:22 PM
2019-09-23 09:40 PM
poco2013 wrote:Could you send that .rpt file to us in email to archicadapi@graphisoft.com please?
...but when I run the exe it only creates a rpt file??
2019-09-26 09:19 AM
2020-08-11 07:27 PM
Tibor wrote:
Dear Developers,
The DevKit 23 does not contain all of the dependency of the AddOnAdmin.exe.
We decided to not put into the DevKit those missing libraries because that way the size of the DevKit would be more than 300 MB and those missing libraries can be found in an installed ARCHICAD.
So to run the AddOnAdmin.exe, please copy the content of the "AddOn Management" folder to your installed ARCHICAD folder (make sure that AddOnAdmin.exe is placed next to the ARCHICAD.exe, in the same folder).
FYI:
We are planning to move the functionality of the AddOnAdmin application to our API Site (http://archicadapi.graphisoft.com). The development is still in progress. As soon as it finishes the AddOnAdmin application won't be part of the DevKit.
That way you will be able to generate new identifiers for your Add-Ons and check your existing Add-Ons at our site without any external application.
2020-08-11 08:12 PM
Tibor wrote:BTW, this solution ruins the archicad installation, so it wont run.
Dear Developers,
FYI:
2020-08-11 08:15 PM
poco2013 wrote:I should mention, that the only working version of Addonadmin (which cant ever save the database as a C header, though), is in AC22 API archive. No idea, why the idea of making an outofthebox dev solution for archicad is so impossible for graphisoft.
Just installed the Archicad 23 API. tried using the Addonadmin manager and got the following error: Any fix available?
On Windows 10
2020-08-11 10:33 PM
